hey im finaly got my buget for my new gaming pc and i waunt to know if i should get a better cpu or gpu the games that im going to run are starcraft 2(cpu intensif) crysis 1 warhead 2 and 3 (gpu intensif)... what is better to get and any recomendation thing to change to the spec to recomend http://pcpartpicker.com/user/pl9090/saved/#savedbuild_231912
im trying to spend between 600$ to 770$ mabie higher if need it
That build will be able to handle what you want to play just fine. If you want to you could get a better processor and still be within your budget, but your current one is good enough.
I think the build you have is pretty good, though I would probably try to get money enough for something like an AMD FX6200..
if you are willing to use a little more money then you could also get a i5 3470k.. unless you havent listed everything you need in the PCpartpicker link..
