Best Wireless Gaming Headset?
I'm looking for a good gaming headset for the PC that is wireless.
I'm not sure how much wireless headsets go for but my budget is a maximum of $200, but I'd rather $150 ish (or less).
If any have a good quality mic, or any at all it would be preferable, but not neccesary.
Thanks
Edit: Okay so I just quickly looked around and found the Razer Chimaera headset.
There are two versions, a $130 one that's just called the Chimaera and a $200 one that is called Chimaera 5.1
What's the difference between the two, and will I be able to tell the difference?
I'm fairly sure Corsair do a good one.
Your best bet is going to be the Logitech G930, which is wireless with the included dongle (~$99).
Also try looking at the Razer Chimaera headset, it's available in 5.1 (~$180), and stereo (~$150). However it is not completely wireless, it has a base which connects via 3.5mm.
Based on Razer's reputation for headsets (they still have yet to master good mic quality), I would recommend getting the Logitech.
