Best way to speed up an APU?
Hey,
Ive been wondering whats the best way to improve APU performance.
Yes i know its not a cpu but its more of a cpu than gpu :P
install faster memory
Faster memory REALLY REALLY REALLY helps! Also, overclocking helps, but faster memory is much more important.
Get Higher Clock Speed RAM, a 2133 mhz or 2400 mhz Speed Memory should be efficient. and Overclock the APU a bit.
If you already have memory, buying faster memory for $80 would be a waste when you can get a GPU that'll blow it out of the water for like $100. You can prob find an HD 7770 or HD 7790 for $100-110
You can buy HD7770's for $80 lately i saw a asus 7790 for $100 yesterday ram costs more than those with the new inflated pricing on ram..
he asked for ways to increase the performance of his APU, not the performance of his gaming or anything else.
+1
Can you get faster memory in laptops im currently using 8gb 1600MHz
