My specs:
CPU: Intel Pentium G860
GPU: Xfx 7770
RAM: Corsair 8GB
Motherboard: MSI H61-P31
Should i just go for an i5, or would i benefit in getting a new amd processor and motherboard. I will mostly be gaming.
My specs:
GPU: Xfx 7770
RAM: Corsair 8GB
What is your PSU?
Xfx 550w 80+ bronze, should be fine
R9 270 doesn't really get a jump performance in terms of FPS compared to a R9 280X / 770.
Depending on your games you play, CPU can be better in terms of quad core such as BF4, WoW, Starcraft.
You would gain more of a FPS performance with a upgrade to a GPU but not with a R9 270 from a 7770.
So, if you want a more higher FPS performance, save up more for a better GPU. Else CPU upgrade.
Edit: Depending on your choice, R9 270 OC will be able to play 1080p ultra with tweaking on certain games. If you want at least constant 60 FPS, a higher tier is better. R9 270 will sometimes dip below 60 in some games.
I've purchased the r9 270, being able to play bf4 on high with a constant 60 fps is perfect for me, a big improvement from playing on very low with the 7770 with the odd drop in fps probably due to the cpu. Since i have purchased the 270, whats my best option now, going straight for the i5 or the amd route.
Ps There has to be vast improvement with that gpu going by the benchmarks...
playing very low on BF3 sorry
Either Intel quad core or AMD FX 6300 or higher depending on your budget. If you are getting AMD, make sure that the motherboard will actually work and supply enough power with your chosen CPU.
i'd say just get the i5 (or an ivy non-e "xeon"), but if you're wanting to overclock you'd need a new board anyway so I wouldn't consider amd unless you're wanting to overclock, otherwise intel will be a good bit cheaper
Any good amd motherboard and cpu suggestions, just for gaming
Sorry overlord never seen your post, probably won't be overclocking. If i'm just gaming would amd not be the better option?
why do you think amd would be better for gaming?
put it this way, last I checked a locked i5 and the fx6300 benchmarked fairly closely with the i5 beating the fx sometimes and the fx beating the i5 sometimes, and sometimes they come out fairly close
i5 3470 - $180
fx6300 - $120 + decent motherboard - $90
so to get similar performance (depending on application) amd will cost ~$30 more
So do you recommend i go with the 3470?
I recommend getting the fastest (clock speed) i5 you can afford, the 3330 is the cheapest and should be decent for about $20 more you can get the 3470 and an extra .2ghz, and for an additional $20 you can get a 3570/3570k which will get you an additional .2ghz
look up some benchmarks and see if it's worth it
