Best way to go about dual-booting (Win7 + Linux) on same mSata SSD?
So I've been dabbling with Linux mildly here and there, mainly in a VM and now I'm wanting to set up a "proper" OS on my drive to use when I'm really just going to do web browsing or anything that doesn't really require me to use any of my work programs on my laptop to somewhat get better battery life and whatnot.
I was given a 256GB mSata SSD as a Christmas present from my partner.
I've partitioned it, giving 100GB to Windows (just OS and software) and there's still a remaining 138GB free along with a 320GB HDD on my Lenovo x230t.
So because I don't want to go store any large files on the drive to potentially slow it down I was thinking of putting one or two different Linux distros on there just to play around and to use it as specified above.
Just wondering if there's anything I specifically need to do in order for this to go smoothly?
I'm thinking of installing Mint or Manjaro, it would mainly be used for web browsing, documents, watching a video (stored on the HDD)...
In Windows I mainly use things like Photoshop for 2D animation along with the rest of the Adobe package.
Cheers,
-Tragedy-
Depends on your hardware. If you have two graphics cards (like on in the CPU and one dedicated for instance) and have an IOMMU capable system, the best way is to install a solid linux distro, and to install Windows in a virtual container with a PCI passthrough, because it speeds up windows, allows for windows snapshotting to solve problems, and runs windows behind the linux netfilter. If you don't play games in windows, you can virtualize even without PCI passthrough (so on a non-IOMMU-capable system), as paravirtualized graphics will be more than enough for Photoshop and 2D animation. It's also the most comfortable solution, because you can run both windows and linux at the same time, and can access the web or mail in linux for instance while running photoshop in windows. If you do play games, you need IOMMU.
I actually run Fedora on my systems, and run a virtual linux container (either kvm or lxc, depending on the application) for running commercial or non-free software like Steam, or for doing experiments, so that my base system always stays clean and fully free, libre and open source. It also allows for doing things that save a lot of time, like installing Steam and downloading games once, and then copying it to my other computers.
