So I have my router and modem on the main floor attached to the computer im currently using. the new PC is in my room. Down here i get about 83Mbps down, and up there it is around 15 using a usb adapter. for about $80, what is the best way i can get a better connection up in my room? not very good at all the wifi stuff so i'd like to know the absolute best way to get a better signal up in my room. THANKS!
I would try to relocate the router to a more central position, and running powerline or enthernet to the PC, that way, everythings get better wifi coverage
you can get higher speeds for more money but since i use it mainly for internet and not inter-home networking 200mb/s is much more than my ISP provides so it works fine. i also like the plug pass though so i dont sacrifice power plugs space for this.
So do i need to buy the cables that adapt to the kit as well or do they come with them? I need these mainly for gaming, downloading movies and such. i get about 80 mbps down on this computer that is directly plugged in to the router. will i get similar speeds with the powerline kit?
