Hi,
What is the best quality price water cooling system ?
thank you
Hi,
thank you
Hi Habelal,
That question really depends on your current setup in terms of how much space you have available. If you haven't got much space I'd look into a small sealed unit cooling solution like the Corsair H80i (120mmx120mm ish radiator)
Or if you've got more room perhaps a H100i (240mmx120mm ish radiaor)
(note the UK sites on those links)
In terms of quality for price over the general spread of products available I haven't got a clue, and i'm just trying to point you in the general correct direction of what you will actually be able to use for your setup. Look up 'Sealed liquid cooling round up' on google (or something similar) and you'll find some really detailed stuff that other people have put a lot of time and effort into. Below is a link to a roundup of 240x120 coolers that I found in about 30 seconds, and there's a lot of stuff like this out there if you're willing to look around a little.
http://www.tomshardware.com/reviews/h100i-elc240-seidon-240m-lq320,3380.html
These closed loop systems are getting very reliable in terms of not introducing a liquid to electronics and are the route that most people end up going when they liquid cool. If you're really looking to push the boat out in terms of price for a little more performance (and mostly bragging rites) have a tentative look into building your own liquid cooled loop. Even if you just research it a tiny bit and say 'Screw that' have a look just to see some really cool stuff that people have built.
So take your time have a good look around for what you want and also what you are willing to spend your hard earned money on!
Hope that you find this in some way useful. If I had a little more information on what you've currently got and the space available i could help you a little more, but this should get you started.
Alex
best performance/price ratio will be a custom loop.
Look up the Raystorm 750 series, they have several different radiator sizes to meet your needs.
Thank you very much !
My specs:
Cpu: Fx-9370
Gpu: Gtx 680
Motherboard: Asus Crosshair V Formula-z
Case: NZXT phantom 820
I prefer Sealed liquid cooling
I prefer sealed liquid cooling...
I do not trust custom loop water cooling
I think the best sealed loop is the Corsair h110, which is a 280mm rad.
The quality of it is dependent on the person that installs it, lol.
With 7/16in ID tubing with 1/2in ID barbs you will never have to worry about that.
Thats what I use. Great combo. Perfect seal.
thank you, I'm pretty sure I will buy the Corsair h110
