Hi i'm looking to upgrade my cpu cooler and i've noticed that i can't fit any of the best air coolers as my memory is to high so looking at water coolers. I currently don't overclock my system but i've noticed that when done with a water cooler the temps are still good. So i'm basically asking for some info as i'm currently looking at corsair h80i or the h90.
Wait for it to go on sale and just pick up the h100i or h100
i would but the only place to mount the raditor would be at the top of my case which doesn't have a great inflow my case is the cm storm trooper
that case has 2 fan mounts in the front, how can it have a bad intake? you got hdds in the way?
If you want a water cooling for your cpu for that price, flatout, h100 if there's some sale,
Maybe the h80, the single thick radiator may not perform as well, but I assume it'll get the job done
Have you ever looked at the Antec Kuhler H20 closed system water cooler?? I to have the cm storm trooper, Fits in there fine. Rock solid cooler. Works great. Just a thought.
The Corsair H100 is on sale on Amazon.co.uk right now, you should definitely take a look at that. http://www.amazon.co.uk/Corsair-CWCH100-Performance-Radiator-All-In-One/dp/B0051U7HMS/ref=sr_1_2?s=computers&ie=UTF8&qid=1360254061&sr=1-2
the case has a bit of conjecture because it says it has 2 front and side fans slots it doesn't as its the fans are attached to the hdd bays
I would say the best under £100 is the H110 which perform close to the kraken x60, link - http://www.guru3d.com/articles_pages/corsair_h110_review,13.html
and you can get it from here for 95 quid https://www.aria.co.uk/Products/Components/Coolers+-+Water/Corsair+Hydro+H110+Water-Cooling+CPU+Cooler+?productId=54045
ok well thanks for the suggestions i'm currently looking at h90 h100i and the h110
