Best use for ca. 2010 Clarkdale i5 655k PC
Recently, I dug out an old PC sporting the above Clarkdale i5 655k processor but with 16GB of DDR3-1666
It also has older PCI-E 2.0 and 7 Sata II 3GB ports
What is a potential use case for this machine or is it something that should be sent to proper disposal?
I installed Proxmox, Win10, TrueNAS and all of these were quite slow and it’s not the most efficient machine, electrically, so 24/7 operation seems a non-starter
One thing I tried that I found quite snappy was Daphile with the ability to stream through Toslink, Realtek 889 sound card, USB or even HDMI
Do you have any other suggestions for this Potato?
One other use case…a backup server?
I really don’t want to spend money on this deadender, but I do have a couple 2TB drives running around that I could use for data
Perhaps a cheap flash drive?
Would a lighter linux server be a better alternative to TrueNAS?
I forgot to mention, I installed OMV first, but after an update destroyed the install (I foolishly forced an update to a new 6.x kernel)
I feel money spent here would be better spent on newer (even used) machines
So, I wasted a weekend farting around but really don’t know where to go from here
Any suggestions would be welcome
Batocera box
Use an older version like 25 or below
It doesn’t have a video card
It’s first gen built in graphics
Is capable of decent 1080p output
Seems like something I should look into
Edit: I can boot Daphile from a flash drive and hook up a USB drive for music and easily dual boot that way
Thanks
Well…now I’m answering my own questions, but I wonder how dietpi or raspberry pi x86 would look like
Offers a simple netboot for a pi on the same network
And mostly, I don’t really want to leave it on 24/7, I have a pi or 2 or even a chinese TV Box that do some Jellyfin, Squeezebox, dns filtering or whatever for single digit watts, so I thnk I’m nixxing those other server ideas, except maybe a backup file server and I can actually boot to individual drives from the bios
I suppose I will end up having 3 or 4 different installs between flash boot and dual hard drive boot
One good thing is the case has room for drives and the sata ports are plentiful
Only the limitations on speed plus relative power hog-iness have me going a different direction
