Best upgrade for current rig upto $1000
Looking for suggestions and willing to leave amd if neccessary. Machine is mainly used for gaming and general use.
Current hardware :
thermaltake chaser mk1 (all optional case fans added)
XFX 1250W Black Edition Full-Modular PSU 80+ Gold
crosshair v formula
1100T
H100
Sapphire Radeon HD 6950 2GB Dirt 3 Edition (used to have 2 in crossfire, but one died)
Gskill ripjaws 2133 CL9 2 x 4G with Gskill ram cooler
Western Digital Caviar Black 1TB x 2
LG DVD combo burner
Samsung 3D 27" S27A950
Logitech z 5500
Razer Lycosa
Razer Naga - Hex
why do you want to upgrade?
surely there isnt anything you cant run
but if you must, a second 6950
definately the gpu upgrade, will my cpu slow down a better setup like twin 7970's?
Also i like playing games with everything maxed out.
no, you cant really bottleneck a system with a CPU unless you have something like a core2quad or first gen phenom X3 or APU and run a cpu heavy game
also going to 2 7970s would be much of a big upgrade since theres only like a 20% difference between the 6950 and 7970, and its certainly not worth the money
sell the 6950 and buy a 7970 or unlock the 6950 to a 6970 and buy a fx 8350 it will give you 10-15% beter preformance
http://pcpartpicker.com/p/vfp7
https://www.youtube.com/watch?v=QUkvhOhrDVk
Thanks for your help. I'll get a second 6950 to re-crossfire and save my money.
i originally built my system over a year ago before the fx cpu's came out, with the intention to upgrade to the 8170 when it came out, however it didnt and the 8150 was worse than the 1100T, i was very sad and dissapointed in amd. The 8350 is what the 8150 should have been. Hopefully the next fx that comes out improves another 10 to 15% and i will get that.
^^^^^^that
7970 and fx-8350.
maybe upgrade to the new kraken cooler at the same time?
the 6950 wont unlock to 6970, so i was unlucky with that one
