Best Type Of Home In Terraria? [Terraria]
Hey guys I am fairly new to Terraria I really like it, I defeated the Brain of Cthulhu as well as Skeletron, currently I have base set up underground with about 8 NPCs, the corruption is spreading I heard you can avoid it by building a house in the sky, but then you get harpies and wyverns, what should I do, and what is the best type of house to build, like for ex. underground bunker, ground fort, sky city, tree house, etc...
Thanks guys!
i tend to build a village, but then bloodmoon means your NPC's will die. another way like you mentioned is to make a floating base, harpies/wyverns wont spawn unless it's really high up, like near the floating islands.
about 10-20 block above the flat forest floor is ideal. may not look the best but makes for a sturdy fortress. enemies will not gain entry and corruption/ hallow will only affect the ground below .
in short. Sky Fort.         (but build whatever you think will be more fun/more badass)
If you're not in hardmode, just plant some sunflowers at the border between corruption and "normal" biome and you will not have to worry about it.
If you are in hardmore, sunflowers don't work. You have to combat corruption with the hallow.
Blood Moon is not a problem at all. Just put some dirt blocks in front of every door and entrance and your NPC are 100% safe.
For biodome protection;
Make a 3 blocks wide gap. It cannot spread then. Corruption OR hallow. Preferably make a wall of pearlstonebrick at the hallow-side, so it can reflect corruption spits, and then leave a 3 block gap.
As for the perfect home, in hardmode those ghost spawn and go through walls. I havent found a solution for that. Its just annoying tbh...
those ghosts can go through walls, and it LOOKS like they fly. really they jump, only afew blocks high.
so sky fortress still the best, what servers you guys play on?
i actually don't play on any public servers for some reason. but i tend to host a multiplayer world for me and afew friends every couple o days.
i just build something like a fortress, and let the npcs live in little shacks in the vally below, except one... he lives on a floating island in a gold house.... because it seemed like the thing to do at the time
Its called Eye of Ctchululuuluulu
