I have 2 little brothers in school, who could benefit from a tablet to store some things they need to know. And maybe some learning type of games. Thing is, cannot really afford to spend a lot on it, under $100.
I am not looking for the fastest tablet out there, just one that is fast enough to work.
I personally like the Asus Memo pad it is 7" tablet running android 4.1 (Jelly Bean) 16 GB of flash and 1GB of ram. Depending on where you get it, i recently bought mine at walmart for only $89.99. So that might be an option
the speed is nothing great especially when you completely turn it off and then turn it back on, it takes a bit to to get rolling but once you start i don't have any problems. But then again you can't really expect much for a tablet that is under $100.
