I'm thinking of building a pc and I'm thinking of ideas for a good quality gaming case, doesn't have to be feature packed, just needs to be solid reliable case.
Really solid case and under your budget so you can toss a little more money into your GPU or couple more games. You will need to get a couple Extra 120mm fans for it though.
NZXT 210 Elite - http://www.newegg.com/Product/Product.aspx?Item=N82E16811146078
With this case, i really don't understand how they are so affordable with the build quality they have. Sturdier than a few other more expensive cases I have used.
Haf 912
I've never used the Half 912 but, from all of the unboxings I've watched on it, it seems really flimsy.
Have you used it before? If so, are they as flimsy as they seem?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811553001 really nice for $50
It's not flimsy at all, in fact, it's considered to be one of the best budget cases out there. Other than that, I'd recommend a Corsair 200R and 300R
No but my friends have and I've see. Them rage so many times and kicking that And his hasn't broke yet it is also very good with airflow
You got me looking at toys I shouldn't be thinking about buying right now. :)
Here is another case, just under your budget. It is set up to mount a radiator at the top for when you are ready to start upgrading. Comes with 3 fans pre-installed, plenty to get you going.
http://www.newegg.com/Product/Product.aspx?Item=N82E16811146080
Only thing I don't like about this one is there is no mount for a fan on the side panel to get air directly to the GPU. Oh well, that's what they make Dremels for.
VersionDrew, I know it is a popular case. It just seems that with the amount of options for low cost cases these days you can get something with a bit more attention to detail. That's just my thought on it and probably only my thought. lol
I think you can find Shinobis for around 80, same with R4's on sale, but if you want to spend less that that id go with something like a Core 3000 or a bitfenix merc/alpha
