Best sub $300 graphics card
i am buying a new pc and i want to see what is the best graphics card for under $300. i am either thinking of the geforce gtx 660ti or the radeon hd 7950. i want to play bf3 and borderlands 2
the 7870 out performs the 660 ti so i'd recommed the 7950 if you can get it under $300. i'm from australia and import texes etc make our pc componets more expencive :P so if you can get the 7950 under $300 go for that, no doubt
7950 on sale by far
Vs. the 660ti,... 7950 will beat it in practically everyway, google it if you don't believe us.
which one of these systems are better
1 http://pcpartpicker.com/ca/p/y1gF
2 http://pcpartpicker.com/ca/p/xuXk
3 http://pcpartpicker.com/ca/p/y1lo
4 same as 3 but with a 7950
i like #4 i have same mobo and cpu(working very well btw) with a 550ti and have been reserching gpu's i want a GTX670 but they are closer to 400$ and am leaning towards a7950 closer to 300$. that said new ones are coming out soon i may put up with 42fps warhead at 1080p with second lowest settings and see whats up in a couple few months. Play around with this: http://www.anandtech.com/bench/Product/550?vs=647
but even if i have a 60hz moniter wont i get screen tearing and doesnt the gtx 660ti have adaptive vsync
