Best sub 100 dollars ear buds
I would like them to be in ear.
klipsch s4i. Don't argue, just buy them and be happy...
spend 30 bucks on earbuds. save the rest and put it away so you can buy a good pair of cans in a month.
Next to if they should be in ear, it would be great if you could state what kind of music you prefer and if you have any preferences in sound. Else the recommendations may not turn out to be to your liking...
I've had half good luck with Skull Candy... I like the audio they give me but they do tend to die quickly (that is likely just me... I put a lot of wear an tear on my headphones) but on the bright side of things they have solid warranty so in spite of having gone through upwards of 6 pairs I've bought 2... So that's a thing...
I second the Klipsche S4i's. If that's too expensive, the S4's are just as good but do not have a volume/song remote on the cable.
If you resolution and accuracy, here you go.
http://www.amazon.com/Etymotic-Research-Portable-In-Ear-Earphones/dp/B000XP8DJC/ref=sr_1_3?ie=UTF8&qid=1366807448&sr=8-3&keywords=etymotic
