Hey guys, I'm looking at a 7950 Vapor-x as I heard it's good if you're not overclocking. But are there any other good factory overclocked 7950s you guys could reccomend?
Thanks!
Thanks!
the vapour-X is an Overclockers dream for a Air cooler card, one of the best aftermarket coolers around.
with all that being said, it should work well if you dont OC it, but why are you going for a pre-Overclocked card, when you can just do it easily yourself.
