Best static pressure 140mm
Hi im looking to overhaul all the fans in my workstation build.
I need 2 static pressure ultra low noise 140mm for my radiator
and 3 standard low noise fans for intake and exhaust
I like the sp140's from corsair with colour rings to suit my black and white build but they are hard to get hold of the 140s in SP form these days.
Any recommendations for black out fans? the noctua ones are nice but hate the brown edges
Check out fractal's Venturi HP-14.
I use em in my case; they're very nice fans
Quiet?
EK Vardar (F1 or F2)
Noctua whatevers
Fractal Design Venturi
Phanteks PH-F140XP (or PH-F140SP)
be quiet! SilentWings 2
Rosewill Hyperborea / Akasa Apache
They're all pretty quiet and have decent static pressure.
Noctua Industrial PPC
You can detach the brown bits.
