Best ssd for ops bootup?
What is the best 120GB Corsair SSD, for a Operating System? I want it to load my OPS very fast! I am not experienced in the SSD department... I like Corsair support so I want to use them. Thank you. :]
If you are set on corsair the Neutron Gtx is the best other wise there are other options as well
You should check out the Samsung 840 EVOs, really good value for money
