BEST SETTING FOR BLACK OPS ii
i just purchase a steel series sensi gaming mouse and i love it so far but there is alot of settings and features you can  use to make this mouse work the way you want; from the CPI to built in accelerator detector, I would like to know what are the best settings to choose for black ops II as that is the game i play the most.
A lot of settings with mouse and keyboard are just personal preference.
i personally run really low sensitivity in game and 4000dpi in mouse driver + 1000hz polling rate for smoothest possible response.
im not sure if that high dpi is even necessary to be honest.
Honestly, if you've been playing without tweaking settings up until now, don't change anything other than the sensitivity. If you're starting fresh, disable all mouse acceleration (both windows and steelseries software) and find a sensitivity you like and never change it (unless you change mice). Personally, I play on a stupidly low sensitivity and dpi, but that's up to you to find a sensitivity you like.
Well i have my settings all setup now but still my mouse doesn't seem to be as accurate, should i use another mousepad, if so what do you recommended.
