Best Ram for A10 6800 (again)
So I am looking for some ram to go in my itx build. I was original going to go with some Kingston beast 2400mhz but I found some Kingston predator 2400mhz for about half the price. Will Kingston predator work just as well? I will be using a GA-F2A85NX-WIFI motherboard and I can not find a sheet of supported memory for it.
They should perform similarly, as both of their CAS latencies are 11.  I can't find the timings on each, so I can't say for sure.  I'd like someone to pitch in, but to my knowledge, they should perform the same.
+1 They look about the same, I would just get what ever seems better priced/looks better to you/has a good heatsink if you plan to overclock, etc. Make sure the predator will not be touching your CPU cooler as it will a huge heatsink on it as oppose to the beast which I think has a shorter heatsink.
Ok thanks I was able to pick up 8gb for about 55$. Do you why ram got so expensive?
This time last year there was an overflow of ram on the market, so OEMs lowered prices to move more stock.
Now there is less ram on the market, so the OEMs have raised the price.
I picked up 16gb of 1600MHz cas 11 ram last year for $65, it's now $150
Also a giant factory that made about 1/3 of all the RAM on the planet burnt down a little while ago, kind of the same thing of what happened with the floods that raised the price of Hard drives.
Is there any chance that the pice of ram will drop any time soon?
Hopefully, other than that, you could probably find a good deal on eBay for RAM. It may take another few months for prices to drop again, maybe even half a year, you just have to be patient.
ok thanks
