I have around €250 to spend so price isn't an issue, while I'm aware that I can get a Sapphire or MSI R9 280X for that price, unfortunately my PSU can't handle that and buying a 280X+PSU is out of my price range. I'm replacing a 5850, so it's still going to be a massive increase in performance.
So what is the best R9 270X in your opinion? I don't care so much about noise, I don't have a preferred brand, and I intend to OC as far as possible, so unlocked voltage is a must. A 4Gb VRAM model would be nice too. I've been doing a lot of research but I can't really decide on a card, people have been giving me conflicting information on how reliable different brands are, I assume based on their personal experience.
So far I've been looking at:
-Gigabyte Windforce 3X
-Sapphire TOXIC
-MSI Gaming
The Powercolor DEVIL also looked very good, but I read that it's volt-locked.
i would recommend The Sapphire R9-270x or the Asus R9-270x.it depends i think most people that buy AMD card will probably tell you to get the Asus Model because it's totally non-reference, its cool and quiet. however the Sapphire model is actually a bit more cooler. but the fans are a tiny bit louder not much that you will notice. however like i mentioned look at the Asus or Sapphire models.
I actually recommend the you purchased at least 280 280x 290 290x 770 780 780ti Reason being that while they are good cards. They are at a point in which they will fall behind gaming wise with the higher demands that new games will require. Yes, what psu are you running?
I am not a fanboy for either company I use both but if it were me I'd grab another 29 bucks and get gtx770. amd cards seem really expensive right now atleast in the states and at a passmark score difference of 1735 (270x=4479/gtx770=6214) thats alot for 15-30 dollars. Mantle is showing a %15 boost and that may effect where it performs I know passmark is not the best comparison but thats where I start usually for info.
Nah, I calculated the wattage and unfortunately a 280X would put me about 10W over the 520W limit. It's also a good idea to have an overhead of about 20% for overclocking and for general safety purposes.
Wow its the exact opposite in the states right now. I did some research for you I dont know if mindfactory.de has shipping to France I am assuming yes but here are some links at some better prices then stated i did not look at the shipping and vat so this is flat pricing. Do a review of the one you get for us :)
jour de valentines heureux, je prends ma femme à un restaurant français ce soir! Hope this translated well
Thanks for your input guys, at the moment I'm hesitating between the Sapphire TOXIC 2Gb and the Sapphire Dual-X 4Gb.
I wish they made a 4Gb TOXIC but it doesn't appear to be the case. What would you guys choose, the TOXIC has phenomenal benchmark scores, above that of a 7950, while the Dual-X has twice the VRAM which would be better for EYEfinity.
520W 80+bronze is more then enough power for a 280X.
A 280X uses arround 250W max, the whole system with a 280X will maybe use arround 380W on full load maximun, and since a system does most of the time just idles arround. So a decent 520W psu could handle it with no problems, unless, its a crappy one. but normaly antec´s are great.
