i have thought about this so far
http://ca.pcpartpicker.com/p/OemQ
is there anything better thant this for $450
(im on a really strict budget)
btw i live in canada
thanks
thanks
Well for two dollars more you can get two 4gb sticks of RAM which is much better than one and double the HDD space.
http://ca.pcpartpicker.com/p/OeG2
Hey for only $22 more http://ca.pcpartpicker.com/user/GhostMistSniper/saved/1qlv
you get better, faster ram and a better GPU it's a 7790 insted of 7770. You can watch this video,
https://www.youtube.com/watch?v=ZqkY62vAr_I to see how much better the 7790 is to the 7770. (it's not my video)
Dont forget the operating system that will cost you another 100$
http://ca.pcpartpicker.com/p/OjQF
650ti benchmark http://www.videocardbenchmark.net/gpu.php?gpu=GeForce+GTX+650+Ti
hd 7770 benchmark http://www.videocardbenchmark.net/gpu.php?gpu=Radeon+HD+7770
Get shawnhogs build. You don't need to buy windows. And lastly, maybe a different psu. Shits 40$ for 460w and not even 80 plus. Might be best tho I didn't look.
