I will be buying a pair of portable headphones around 200. I will be using them mostly on the bus too school and other areas where I would want headphones that can block out sounds and not leak noise either. I am kind of set on the Audio Technica esw9a $200 or the es700 $150. The other headphone I am considering is the vmoda m80 although I am concerned about them being on ear since I have never owned a pair before. I am open to other suggestions but I remember from demoing the Momentums that I did not like the sound so much.
Music I listen to:
-Variety of EDM (pretty much anything on MrSuicideSheeps youtube)
Word of caution; those headphones have a rather high impedance. While they will work just fine on a phone with a good amp on it (iPhone, HTC phones with Beats), some phones may not be up to the task of properly driving them, leaving you with a slightly disappointing sound compared to what they are capable of.
Sadly, Momentums were actually going to be my first recommendation. If your player has a capable headphone amp on it, then the Audio Techicas are a great choice, and would take them over V-Moda's any day of the week; I was very disappointed in their performance (though the V-Moda's may be louder on weaker amps). The other one I would throw into the mix in the same category of headphones you listed was the Sennheiser HD380's. I am a huge fanboy of their products after owning a few, and was amazed how much sound those things blocked out passively.
The best thing for portable would be in ear. Something from etymotic (like the HF5) would block out most to all sound. That would also leave you with plenty of money to invest in a decent dac/amp like an E7 for both portable use (amp) and desktop use (dac and the amp). If you want portable around ear headphones though, I can't really help you.
I already have a e17 and an e09k but I already have a JVC HA FXD80 but I don't like using IEMS for longer periods of time. Also decided to get a pair of Sennheiser Amperiors.
