need new speakers to replace old walmart logitechs.I watch alot of streaming online and very light gaming.what would be the best choice?budget at $250 max
Why not go with a pair of headphones? You can get much better sound at that price with headhpones than you would with speakers.
Corsair SP 2500
im not a headphones kind of guy.just like to have good ols fashioned desktop speakers
Here are some options. If you think that you really need a subwoofer (I would suggest waiting until after you have the speakers to see if you think they need it) then you can get a separate sub to add in.
http://www.theaudioinsider.com/product_info.php?p=swan-d1010-iv-active-desktop-loudspeaker-system&products_id=166&osCsid=7868d5559fcdb1572f9fc3b46bf21f0e
http://www.amazon.com/Audioengine-Premium-Powered-Desktop-Speakers/dp/B000VKEFN2/ref=sr_1_5?ie=UTF8&qid=1374458684&sr=8-5&keywords=audioengine+a5
You might also want to consider gettign a sound card or a dedicated dac.
EDIT: These are on sale. You might want to consider them if you want a flatter sound (more accurate).
http://www.amazon.com/KRK-RP8G2-Powered-Studio-Monitor/dp/B001A6IGDG/ref=pd_sim_sbs_MI_5
