so i need a power supply a hdd a cpu cooler and a case. I also need a new gpu but i think i am pretty sold with the new sapphire r9 280x toxic edition for its performance, unconfirmed $350 price tag and overall sexiness. i am not 100% on anything in the build as there are lots of options out here, this is what i have so far,
http://pcpartpicker.com/p/1NhQs
I already bought the cpu, mobo, ram and thermal paste
i also found these links for a refurbished sabertooth 990fx tell me if these are trustworthy.
http://www.snaggstuff.com/sabertooth-990fx-pb-r.html?cmp=googleproducts&kw=sabertooth-990fx-pb-r
http://www.cedarpc.com/product/30584/ASUS-Sabertooth-990FX-R2-0/?gclid=CPmE95_KjboCFed_Qgod5kIAhw
http://pcpartpicker.com/p/1Ni6O
This would be better mother board is almost as good as the sabertooth
forget to mention that i will be gaming, and thats about it. i would like to do crossfire and overclocking. but crossfire would require too much wattage, thus more money spent
the corsair memory is tall.. if you would have gotten something that wasn't so tall, it'd be better. yes, it's good memory, but it's not the only good memory out there... i like that you went with 1 stick, though, that way you have more options for upgrading later..
if you go to amazon, you can get the nzxt source 210 elite case for a couple dollars less. i just got mine this week, actually. i'm pretty happy with it. :) it's got some noisy fans, though.. so i'd recommend buying some alternate fans for it, if that is something that will bother you... guess you can't have everything. lol but yeah. :) it is a nice case. here's the amazon link: http://www.amazon.com/NZXT-Source-210-ELITE-Midtower/dp/B005869J4O << it's got a usb 3.0 port in the front, which can be handy. :)
you probably won't like that wireless adapter. i can understand why you picked it- cheap. lol but it probably won't be very strong.
might consider something like this: http://www.newegg.com/Product/Product.aspx?Item=N82E16833166073
as for the motherboard- if the asus one is the one you really have your heart set on, then get it. :)
the only reason i am worried about getting it is because i am worried about the website i posted, should i be?
