Just built my first pc, and now looking for my mouse, keyboard, and a headset. I would prefer a mechanical keyboard, and honestly have no preference for either a mouse nor a headset. I am right handed so any good mouse for a right handed user would work. Leave your recommendations below!
It depends on what you are gonna use this for. If gaming, how many buttons will you need? DeathAdder is a nice cheap and very popular mouse and has two buttons
Generally keyboard is all good as long as it's mechanical, you should check out some in stores to see what switches you like I have a corsair k95 and i like it for all the macro buttons
i don't know too much about headsets D: if you have nice headphones get a modmic, if not, i havent a clue. I have atro a40s and theyre good enough for me
for mice if you want light and simple, i'd recommend the logitech g100s. If you want average weight with 2 side buttons, the Zowie FK1. If you want a heavier mouse with lots of buttons, the logitech g502.
with mechanical keyboards, i'd recommend cherry mx brown switches. I won't bother recommending a specific keyboard
they started a good series on headsets https://www.youtube.com/watch?v=3fD-M1F6L4g&list=UUNovoA9w0KnxyDP5bGrOYzg
Purely for gaming I like the Roccat Kave 5.1 headset. It has true surround with separate drivers, makes a big difference in competitive games like CS:GO and sounds epic in BF3. May not be the best quality audio but I haven't had anything else to compare it to.
Got a K70 and K65 keyboard / mouse on order, they seem to be well rated. Haven't used mechanical before but went with Cherry Brown, again seems to be well rated and a good all-round switch.
Mionix Naos for right handed Avior for universal.
WASD V2 with black switches, colour as preferred.
Build your own headset.
MassDrop have a drop for the Mionix 7000 series at the moment (~50% off for both models) if anyone is interested, www.massdrop.com/buy/mionix-avior-7000
