Title says enough
Im from the us so use usd
Title explains but heres the build
also cheeper is better so if i dont need a 70 dollar board thats ok
I am not overclocking
http://pcpartpicker.com/p/305jw
thanks
Title says enough
thanks
Just grab something that is an A75 chipset or higher. This will grant you sata3 and an internal USB3 header.
is 88x better then 75?
its like i get no help on this website
It can be pretty hit or miss sometimes. I don't know much about AMD, so I'll just do this:
Bump. Can someone with knowledge pitch in here?
Yes, the higher number denotes a better chipset. Any given brand will be suitable, but you might want to choose something reputable like ASUS.
You'll want to make sure you go with an FM2+ socket motherboard to leave the door open for future upgrades.
I would recommend the ASRock FM2A75M Pro 4+ http://pcpartpicker.com/part/asrock-motherboard-fm2a75mpro4
For just under $70 it offers a pile of features including crossfire support (so you can add a 2nd R7-265 later on) as well as 4 ram DIMM slots for easy memory upgrading.
$70 is a really good price for a motherboard that offers this level of features. You could go cheaper, but those boards do not support crossfire and lack other features. The VRM setup on the board I recommended is much more robust than the cheaper boards and even though it lacks any VRM heat-sinks, I wouldn't doubt it's probably capable of a achieving a decent stable overclock on the 760K.
Try to stick with manufacturers like Gigabyte, Asus, ASRock and MSI.
Thanks so much
