I'm planning on building a pc with the AMD FX 8320 and an XFX Radeon HD 7950.
Is the MSI 970a-g43 a good enough motherboard for this build or should i buy a MSI 970a-g46 instead?
Are there any other good am3+ motherboards that are under £65/$90?, if so please tell...
http://www.tomshardware.com/forum/330572-30-970a-warning Read this
According to MSI when the fx 8350 reaches full load the mosfets will overheat, so the bios tricks the cpu into throttling so as to not damage anything.
http://www.amazon.co.uk/M5A97-EVO-R2-0-Motherboard-eS-ATA/dp/B008RPZ5H8/ref=sr_1_1?ie=UTF8&qid=1380461045&sr=8-1&keywords=asus+M5A97+evo
Asus M5A97 evo R2.0 is the best 970 chipsetboard to get. with 6+2 powerphase and digi vrm. This is the only cheaper 970 chipsetboard i would personaly recommend for a powerhungry FX8320/8350 cpu. but it will cost 78 pounds. notice that non 970 board is made for CF setups. in that case you realy need a 990FX chipset board.
