Best motherboard for 90$?
hello, i'm getting a new processor (amd 8320) and wanted to know what is the best motherboard for under 90$.Whatever you guys recommend to be the best , im not brand picky or anything like that.Thank you to anyone who reply's!!!
well its gonne be hard to get a decent motherboard for a powerhungry 8 core for that price.
i think this one would be your best bett. im not realy a fan of gigabyte am3+ boards i have to say. But this one seems to be a new model.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128651
I personally use the Asus M5A97 R2.0 with a 6300 overclocked and should be good for your needs.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131873 $94.99
http://us.ncix.com/products/?sku=76522&promoid=1223 $92.99
http://www.amazon.com/ASUS-M5A97-R2-0-SATA-Motherboard/dp/B008V9959O $94.99 + Free shipping
http://www.microcenter.com/product/398235/M5A97_R20_Socket_AM3_ATX_AMD_Motherboard $94.99 / $76.96 open box.
There may be better board but close to your price range is hard to do without cheaping out. The LE version is often found to be circa $15 cheaper, but that's up to you.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131872 $89.99
http://us.ncix.com/products/?sku=76798&vpn=M5A97%20LE%20R2%2E0&manufacture=ASUS&promoid=1122 $88.78
http://www.amazon.com/ASUS-M5A97-R2-0-SATA-Motherboard/dp/B008V99350/ref=sr_1_1?s=electronics&ie=UTF8&qid=1387399096&sr=1-1&keywords=m5a97+le+r2.0 $74.99 +free shipping
i would personaly recommend not to cheap out on a motherboard, if you plan to go with a powerhungry 8 core, i would advice to go for the Asus M5A99FX Pro R2.0
Personally I'd say either the last one you say or Sabertooth, but round this time last year I have pretty much the same issue. Only this one is luckier to get the 8350, UPS had broke my system and those had $270 to get the board, cpu and ram. the M5A97 R2.0 (has anyone ever seen the R1.0? *shake head*.. meh) fx6300 and 8GB Corsair vengeance. Budgets suck...
If I were this person, I'd be more likely to go M5A97 R2.0  or the Gigabyte one. There is also a MSI one that's in the same range (http://www.newegg.com/Product/Product.aspx?Item=N82E16813130637) that's 79.99 but not sure on that one. Personal beef with MSI in the past. $90 just isn't as much as it used to be
