So the title says it all, best monitor for that 400$ price range, shouldnt be more than 23-24 inches ( less inches is fine but the more the merrier lol ) Its mainly for gaming and I dont care for 3D, so basically not a TN panel
Ive already this in mind, the Asus PA238Q but want to see what you guys suggest!
Thank you!
The BenQ XL2420T (http://www.newegg.com/Product/Product.aspx?Item=N82E16824014270) is absolutely fantastic for gaming. I know you said you didn't want a TN panel, but it was the first thing that came to mind. You can get $30 off promo code on NewEgg if you hurry. It'll end very very soon. I hope this helped? :P
Not sure if it's the best but it's a personal favorite of mine, these are loaded throughout a startup lab that I work in and I think they're the monitors that you see in the background of the tek, though don't quote me on that.
Will check them out! thanks for the responses!
