Best mitx/matx case?
What's the best case that can be small and quiet? Few I've found myself: fractal node 304, define mini, bitfenix colossus matx.
Go with whatever floats you boat.
The Colossus is really cramped, Define is roomy, and the Node 304 is anyones guess
So, which would you choose?
The 'unnamed' mITX case Nanoxia had at CES this year is the one I'm waiting for. It will have room for two 280mm radiators. The best watercooling mITX case I know of, schuld be released in the coming year.
For mITX, I'm waiting on the EVGA Hadron Hydro, although for air cooling the Hadron Air looks great too.
The next in line for me would be the Xigmatek Aquilla, if going the mATX route. Although I'm awaiting more information to see how watercooling can be done in that, as that is important for my next build.
The Bitfenix prodigy Mini-Itx case I hear is great and is $79.99 on NCIX.com
thanks guys i think i would just go with the node 304.
I've got the Node 304 and love it.
Great choice, yeah.  Modular, and if you have the right motherboard, you can fit extremely large heatsinks in it.  It'll also allow for 120mm radiators, and 140mm radiators(to a lesser extent)
