Best Mini-ITX Motherboard For Gaming?
hello everyone, i need advise what's the best mini-ITX motherboard for gaming, i dont want to spend more than $160 australian and im planning either buying 3470 or 3570k processor with Gigabyte gtx 660. thanks alot.
By far the best ITX 1155 board is this:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131840
Its not 160 dollars but if you get a 3570k, you can overclock it a lot better.
If your dead set on not going over 160 however:
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157312
If you're not going to overclock, ASUS P8H77-I. Sweet, affordable, and loaded with all the stuff you need.
