I cancelled my order on an MSI z77ma-g45 and decided that I'd pull the trigger on an Asus Maximus V Gene motherboard.
Before I do that, are there any other mATX boards to consider that'll be better?
why not Hasswell Asus VI gene or Asus Gryphon?. if you allready have a ivy or sandy bridge cpu, then the asus z77 V gene is one of the best boards to get.
Yeah, just replacing my cheaper 1155 board.
Then pickup the Asus Z77 V gene, if you realy want a high quality board. I also did not read bad reviews about the Asrock Z77 Extreme 4M, but i know for sure that the Asus Rog is better quality. ☺
That msi board is a board that i would personaly also not buy.
