Best mice for CS:GO 2015
Hey guys just want your opinion on what new mouse I should purchase. I'm looking for an really overall amazing mouse for CS:GO. I was thinking about getting the Mionix Naos 7000 due to its great optical sensor.
I own and absolutely love the Logitech G402 and would definitely recommend it. It's really well made and has great accuracy - definitely felt a difference using that over my previous laser Logitech M305.
That said, it's the only gaming mouse I've owned, so take my advice with a grain of salt.
Would the best mouse for BF or COD or UT or any other FPS be the best mouse for CS:GO?
Best optical sensor based FPS mice on the market (quality/precision/R&D)
Logitech G402 Hyperion Fury
Razer Deathadder Chroma
Logitech G502 Proteus Core
Logitech G303 Daedalus Apex
See mouse sheet here
Well I'm MG and use a cheap red dragon mouse because it's light
Ed over at LTT is legendary eagle or whatever and he seems to like the final mouse now
The immortal Fatal1ty prefers the zowie mice currently
and various pro players like razer mice like the deathadder and mamba, and others like what they like
So, really it's whatever you want, but overall my 13 dollar mouse is pretty solid, the tracking isn't 100% smooth though, since it only has 4 tiny teflon feet on it.
My favorite one is Razer Deathadder. It is comfortable, fast and it has a really good design, in my opinion. If you want to check out CS GO mice in details, you can use this list >> Best mouse for CS GO list
I ended up going with the Mionix Castor, it works really well and have ranked up from gold nova master to master guardian elite since.
