Best mic for around (50£)
Im looking into a new mic as the one I have is starting to cut out.
Im looking for a Blue Snowball type mic. Any suggestions?
For £60 you can get the Samson Meteor which is a bit better than the Snowball.
If you could strech another £30, the Tascam DR-05 sounds quite good (In my opinion better than the Blue Snowball and Yeti, as well as the Samson). It's a stereo mic that can output to a microSD card while on battery, or to a PC via USB.
Meteor is a great choice. Right now its on sale on massdrop.com
Thanks for the advice. I found another mic that i liked better. The sound quality may not be as good but it looks way better imo.
Auna MIC-900 USB
