Anything Ubuntu-based is a waste of time for gaming basically. For performance, you need bleeding edge.
For the moment, I get the most performance in games on Fedora and Sabayon KDE, especially the latter is impressive.
You want a modern display server, that means Wayland, so you're going to want to use Gnome, KDE or Hawaii as DE. Gnome is a bit of a special case for the moment, it's a RedHat project and they like to experiment, and Hawaii is still very beta, so I would definitely suggest KDE. XFCE, LXDE, MATE, etc, don't support Wayland, so they're going to perform less well than the others. Cinnamon is like the buggy bloated version of Gnome (and Gnome 3.10 has a menu option that can make it look exactly like Cinnamon if you want to, but without the bugs and the extra bloat).
You definitelz want the latest possible kernel (now 3.13), so that means Fedora, Gentoo or Arch based distros. The difference in gaming performance of the latest kernels and mesas is huge (60 % or more on some systems), so that's a no-brainer.
If you like really easy, go for Manjaro, which is Arch based. If you like the ultimate Steam integration and the very last bit of performance, go for Sabayon, but know that it's a more complex and powerful system. If you don't mind RedHat limiting some of your freedom of choice (well, it's nowhere near as bad as Ubuntu, Mint or the other McDonalds crap, but for me, as a long time linux user, it's unacceptable), go for Fedora, it's still the most bleeding edge and the most minimal distro of them all.
