Best linux distro?
hello all, i just wanted to know what is the best linux distro to install on a laptop running a single core CPU @ 1.5 ghz, with 256mbs of ddr2 ram @ 400 mhz?
i have already tried mint 15 since i had it on a memory stick already and it just keeps crashing
thanks
Arch Linux is one of the most bleeding-edge distros and will work with your hardware:
https://www.archlinux.org/
It is one of the most difficult distros to install because you start from command line and have to setup almost all the components of the operating system manually. It is very well documented though and there are many tutorials on how to install it:
https://teksyndicate.com/forum/linux/quick-and-dirty-guide-arch-linux-installation/158212
thank you, i will look into arch for the future...but for the mean time i happened to find a 1gb stick of ram laying around and it seems to be doing the trick
Some will say Debian, some will say Fedora, some will say Arch. It all depends on what you want. There is no best Linux distro. If Mint 15 is running fine on your computer, then by all means keep using it.
Give puppy Linux or Lubuntu a try. Both are built for older hardware.  Tinycore Linux only needs 64mb of ram you may want to try that if the others don't work.
also there a couple of arch based distros if you are a little afraid of the command line set upone of them is not completely compatable with arch and it is called manjaro (http://manjaro.org/) the other one is called antergos (http://antergos.com) which gets all updates and packages from the AUR, arch user repository, personally I prefer antegros since it is arch that is just preconfigured instead of built from scratch
