I'm working on an itx build thus the need for Intel, but I've only explored amd options before this. Pretty much just going to game with this. Thanks!
Probably something like an i5 4440.
While checking that out I found the 4460 for ~twenty more dollars. Worth it or no?
It is your call. They are the same except for clock speed. The 4460 is only 100mhz faster.
Thanks!
i5-4590
for 200$ an AMD cpu is a better buy.
1: x58 motherboard from ebay
2: Xeon x5650 or x5660 from ebay
3:Overclock the hell out of it
4:????
5: Profit.
For reals though, a x5650 overclocked looks to have better single core and multiple core performance than the 4th gen locked i5's from what I have been able to tell. Waiting to get my Noctua CPU cooler to test out what mine can really do.
You do know that ">" means greater than... Therefore you're asking which i5 processor performs the best for OVER $200.....
you mean <200$ ?
Chep i5 or xeon on sale .
If mini itx as you say , stay wit the newest intel lineup
see if their is a cheep processor on sale on the forums. they pop up occasionally. also what socket? 1150 im guessing?
that xeon does not have better ipc then an haswell i5
for $200 an 8350 makes the most sense
+1
Where do you live. Do you know anyone near a Microcenter. They have i5 4690K's for 199
