Best HTPC Motherboard
I would want something that had great audio so I could hook up my home theater system to it, USB 3 in the I/O and front pannel connectors, PCI-e 3.0 for gaming, SATA 6Gb/s. Using an i3-3220.
what case are you using
Fractal Node 605.
The Node 605 supports SWTX board, right?
lol I think he means HTPC features like how a lot of ATX gigabyte boards have Mini PCI-E or mobos that have wifi
I plan to get a seperate Wi-Fi card :)
Maximus V Gene. Try to find a used one; it comes with a dual-band wifi card; very well built.
