Id like to have no problem adjusting the outside monitors closer to me for better angle. And have everything perfectly straight.** IM OCD on that I want all the monitors close together, lined up**. Not sure the one im looking at will deliver, So i ask those with experience :P
Why buy 6 of those over a few 4k displays? You could buy 2 4k displays now and add a third in the near future for that budget, you're get 2 1080p displays worth of extra pixels as well going 4k, and twice as many pixels going with 3 4k displays
Good question. First, 2 monitors = no way id be happy with 2. Im use to atleast 3 by nature. As for 4k, Didnt really think about it, But honestly for 23" 4k prob wouldnt do anything for me other then make everything smaller. And with my budget x3 4k monitors (assuming) is out of my budget.
The other thing would be just organization, having 6 monitors each setup and laid out for exactly what i want.
Like 40" 4k displays would basically give you 8 1080p displays to work with though, and then you wouldn't have bezels, and there's software to split up your display into grids
True, However can you budget x2 ( sadly not 3) 4k monitors that are decent into $800 budget? On top of the required Gpu upgrade ill have to do lol. Honestly not a huge fan of 4k yet, Really (praying) that vr takes off.
in a perfect world i guess id have x3 4k monitors maybe 27" tops. If i knew i could run every single game under the sun atleast solid 60fps or atleast my main games but that time just isnt now and i have no need nor want to want.
Also what GPU were you going to go with? as there's like a 7750 with 6 display port outputs - -
You'd get 2 now, which would give you more pixels, and you can add a third later, which gives you this ungodly amount of screen space, if you invest in the 4k displays now, you're never going to have to buy a display set up again.
stacked 1080p displays are going to be as big as a 40" 4k display anyways
You don't want to go 27" as it's a bit small for productivity
This might be the one to get given that it has a 100mm vesa mount
and barnacules has a whole write up on his 3 4k display set up
Any recommendations for a x3 monitor setup? Link to monitors would be a appreciated. So far havnt seen anything that budget wise that caught my eye. Even if i start with just 2 4k, around a grand budget give or take?
I've bought a korean 1440p display and it's perfect, he seems to have just had really bad luck, or all the good panels were sold out at the time, otherwise the TVs he ended up with cost a good amount more, as do standard new 32" or higher 4k displays, they start at around $900 from what I can see on the PC part picker
it may be costly now but it's easily going to be a worthy investment when you compare the cost of the 6 displays+mounting solution for that vs this, also adding in the video card you'd need for 6 displays
ya PC part picker is probably missing a lot so look around, there's a Phillips 40" one here for $700
Another Korean display here, the catch seems to be that it only supports HDMI 2.0, also the latency is probably sub par due to the TV tuner
