I need a new headset for gaming since my turtle beach x11s aren't cutting it anymore. I watched Logan's videos about the build your own headset, so thats what I'm planning on doing. I was going to go with the Superlux HD668B's but they are no longer $40 on amazon and the stock comes from china which means over a month to get them, so In my opinion its not worth it. I also checked eBay and no luck..... Any other ideas you guys have?
SR60i is a good option if you want open back
What region are you because here in US Amazon HD668B is $44.90.
Im in the U.S. But if you check the seller of the HD668B's the seller is a distributor from china which means long shipping times
It's faster than you think. I ordered SMSL SD793II Jan. 7 and it said between Feb. 2 - Feb. 18 for deliever estimate but I got it Jan. 20. They over estimate overseas shipping from my experience.
Kingston HyperX Cloud JUST GRAB THEM THEY ARE 69 ON NEWEGG!1!!
I second this i'm using them right now, even Logan thinks they are good and he hates headsets!
