So, what is the best headphones under $50?
More specific please? Just "Best tech under $50?" can mean anything. What kind of things are you looking for?
How about, headphones.
Superlux HD 668B
As above. Superlux HD668Bs are great value, combine with a Zalman clip-on mic for an awesome gaming headset.
I got a pair of Samson SR850's for like $30 on Amazon a while ago. They're great and they're really comfortable which is something I've heard the superlux aren't.
Thx gonna get the superlux HD668B, I already have a snowball so I'm good on the mic. :)
Razer guy here, know they aren't the best headsets. I picked up some krakens refurbished for $36 so I decided I might as well match my setup and use these for a short period of time til I pick up something better, but for the money these are decent. I'd only pick these up refurbished since they are "gaming" headsets etc.
Also Logan has a video about custom gaming headsets and such and it's a great watch i'd check it out.
Ya I saw that video a couple of days ago, my friend used to have krakens pro which I thought was good and its better than what I'm using atm, but it felt more bassey. but thanks for the tip.
It depends on the purpose you use earbuds for, such as travel, for basshead or for game. Every kind of this has pros. I have Sony MDRXB50AP, Extra Bass Earbuds because I love music, I can buy it cheap and have quality sound. In order to choose ones for you, click here to see them http://www.thebestearbuds.com/best-earbuds-under-50/
Edifier H840 is the perfect headphones you can have, without spending a lot of money.
Holy necro
If you want to go really cheap the basic Monoprice DJs aren’t bad FWIW
https://www.monoprice.com/product?p_id=8323
