To start off, I have Logitech G230’s and Superlux HD668b w/ Zalman clip on mic. I want to upgrade my audio, but I’m going to get headphones as a present for Christmas. There is a budget of around $100. I would REALLY like it to be under $80 though. I would prefer headphones that are somewhat appealing to the eye but the sound matters most. I play Counter-Strike so I need to be able to hear footsteps. Also, I listen to rap so I need some decent bass.
I've had a pair of these for almost 10 years i believe, use them everyday, still going strong. The only aging sign it shows is the crackled foam coating on the inside of the phones and where it makes contact with the top of my head.
The HD 518's are open-back, not closed. Just FYI. If you're willing to go open, however, I'd recommend them for almost everything you're looking for. Good bass, comfortable, and perfect sounding for games and music. I've owned a pair for over 2 years.
