Best Headphones/sound card
What would you guys consider the best headphones / sound card. They do not have to have a mic. Im trying to keep the price for the both of them under $300. Thanks!
Im using Beyerdynamic DT770 Pro 250 ohm with a Xonar STX and they sound great, they should be under your price limit combined, some people also recommend a Fiio e7 or something but i havent looked too into it
its the fiio e10 its a dac and amp will support up to 300ohm impedence im lookin to get that and the dt770 how are they?
The DT770 Pro and STX are a great combo, but since he doesnt need a mic, maybe he should consider something like a Aune X1 or T1 instead of the STX.
