Right so i'm going over to Canada for a few weeks do see family, (from the UK) and i've been looking for a good set of headphones for music (Rock, Punk Rock and Acoustic mainly). I've got around $220 to spend but can go up if there is a big difference in quality. If anyone has any ideas please share:D
Damn, headphones are expensive up there. I recommend both of these, they have very different sound signatures so I recommend you do some research on your own to determine which will work best for you.
http://www.amazon.ca/Audio-Technica-ATH-M50x-Professional-Headphones/dp/B00HVLUR86/ref=sr_1_4?ie=UTF8&qid=1395961218&sr=8-4&keywords=ath+m50
http://www.amazon.com/Sennheiser-Headphones-Burl-Wood-Accents/dp/B0042A8CW2/ref=sr_1_4?ie=UTF8&qid=1395961279&sr=8-4&keywords=sennheiser
You don't really need an amp for either of these to reach decent volumes, but you may get a slightly better experience if you use one, especially with the HD 598, any of Fiio's lower end products such as the E6 or E10 will work well.
