Best hackintosh for under $800?
I am going to be putting together a $800 or less hackintosh.  Here is my build...
http://pcpartpicker.com/p/TNYX
if you have any critisizm on my build PLEASE COMMENT THEM BELOW!!!!!!
seems awesome, is that motherboard the same as the UD5H in terms of hackintoshability? (new word invented, woohoo)
yes it works great with lion and is very affordable!!!!!!
nice
Should be find; consider switching to a 7870, unless you will be doing heavy Adobe work.
it's mac so adobe wouldn't be an issue, unless you'd be doing editing in windows on a hackintosh (that'd be strange to say the least)
I took another route: Scratched the GPU, stepped up to an i7 and added an SSD. All in a mITX enclosure.
http://pcpartpicker.com/p/TS3p
ok thanks guys and i was just wondering is it worth it to spend the extra $100 to go with a 3770k or will a 3570k be just fine for a hackintosh?
yuup
thanks pretzel, I was literally looking to build a cheap hackintosh system for one of my teachers.
No problem
