Simple question: What is the best GTX 760 for gaming (in general) in your guys' opinion? Let me know.
Thanks!
Thanks!
There's going to be some variance. You might get an ASUS that beats and EVGA. Then another EVGA that beats that same ASUS card.
Choose a 760 from any reputable vendor. The aforementioned vendors and MSI are pretty common choices. Give a good balance between acoustic and thermal performance.
I'd be comfortable buying from any vendor, personally. PNY or Zotac. I suppose EVGA would be the most confident choice to make, because their customer service is the most reputable.
The bottom line is that there's no such thing as a "bad" 760. They will all perform admirably.
Thanks!
The Hawk 760 by MSI i believe and its an end of story. That card has the best oc reports and out of the box supports higher voltage.
