Hi, Im building a gaming rig and I need a GPU. I'm looking at the HIS 7870, XFX 7870, and EVGA GTX 660 Superclocked. I want to know what os the BEST possible graphics card I can find for $240 or less.
Thanks
Thanks
7870, hands down. That card should be in the 300 - 350 price range with all the power it has. Plus you can get aleast two games from it, and if you are lucky and get it at the right vendor you can get about 4 games with it.
Agreed ^ 7870 ftw
Though I did see a deal on newegg for a 7950 for $260 a little while ago
The XFX 7950 is still $260. Personally, I would save up a bit more and get that. Its only slightly more expensive and way more efficient. :)
