What is the best graphics card for 350$ dollars want to play some games in maxed settings others in very high settings any ideas?
I own a 660ti and I love it , I've found a kinda bad-ass edition on newegg and it will run you exactly 350 bucks . Someone may also consider an AMD replacment of this card , but it's your PC , so choose what you like the best . Hope I helped !
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130817
Nvidia: http://www.newegg.com/Product/Product.aspx?Item=N82E16814127675
AMD:http://www.newegg.com/Product/Product.aspx?Item=N82E16814202003
The AMD is a great deal, it comes with three games, good ones I might add. But if you plan doing anything with Adobe products then I would get the Nvidia because Adobe takes advantage of the cuda cores. However the nvida comes with Borderlands 2 and an Assassin's creed 3 cuopon. The Nvidia is a faster card though. The AMD will run cooler buecause of the aftermarket cooler. If you wanna save thirty bucks or you want the games the AMD card comes with then get the AMD but If you want an overall faster card spend the extra 30 bucks and get the Nvidia.
Hope this helps,
Warren
I would have to say the 7950. Although there may some GTX 670s out there for that price range you just gotta overturn some stones to find them.
