What is the best graphics card for 270 USD? im looking to get one in the next few days. im gonna be using the gpu at 1080p at 60hz and id like to either max out or close to max out games and stay at pretty good frame rates(60+) since i am coming from console gaming.
I would certainly wait for the 1060 to be released and yes the SLI bridge was removed but that may not necessarily disable SLI as the bandwidth for those cards can probably be handled by the PCIE Bus if they allow it of course.
There is not much difference in performance. But nvidia makes gpu and arm cpu. Amd makes gpu and x86 cpus and gpu. If you are not a fan of any of them then make a choice based on price and performance of you're budget. And there is no bad question only bad answers ;)
Might add more confusion but the 1060 will be faster out the box now with the majority of DX11 based games. The RX 480 may become relatively faster as DX12 games become more prevalent. Though I still think it will be similar to the 1060 rather than significantly faster at best. That's comparing the 8GB version of the RX 480. The RX 480 4GB version is cheaper but is affected by some of the more demanding graphically intensive options in certain games.
If you were intending to keep the setup for a couple of years at least then I'd go for as much VRAM as you can afford in your budget now for future proofing.
